I have 2 different models of Magnavox DVD players. 1 is a dvd/vcr combo (Model MDV540VR/17, I think). I just recently purchased Model ZC352MW8. The remotes seem to interfere with each other even though they are in separate rooms.
Is there something I can do to modify the signals for one or the other?
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
SOURCE: jumbo universal remote
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
SOURCE: dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
SOURCE: remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
SOURCE: my tv shuts off
I picked one up in the trash 2004 model 27MDTR20/17. I turn it on and it shuts off. I opened the back and pulled the DVD/VHS board out. I removed a metal cover on the VHS housing (three screws). There was a broken clear plastic rod and one of the gear stop plastic cords (on the left side) was ripped where it attached to the front metal bracket through a hole in the plastic tab. The plastic chord has a piece of white felt like material attached to it. I epoxied the plastic rod back and put a piece of tape over the broken plastic end of the cord. The tape was folded over the edge of the plastic and then wrapped back on itself. I trimmed the outline with a scissor and poked a new hole in the end where the original hole was under the tape. I attached the chord back to the metal bracket. The problem was still there, the power would go off after a few seconds and the VHS gear train would make a slight motion like it was getting stuck. I then removed the mounting screws on the VHS housing and lifted it off the board slightly (ther are 2 screws that need to be removed from the far side also). There is a small gear under the right side of the board that was not aligned with another gear. The alignment is between a pin on one gear and a hole on the other. After I aligned them I reassembled the unit. The power stays on now only if I leave a tape in it but the DVD and VHS seem to work. My problem now is that I can only select AUX and channel 2! On well thats my next battle. Good luck.
