I cant find the driver online, i am just guessing its the driver as z1 connect fine..i am new t z7 so i thought may be it needs a different driver!
You can choose www.acyberkey.com to get windows, it is helpful
When you bought the camera,is the seller give you the driver CD?
normally,windows 7 doesn't need any driver to connect a device, there's might be an error when the windows installed the driver
I recomend you to go to the Device Manager,uninstall the current driver,and try to connect your camera again,the windows will re-install the driver automatically
And if you can't find the driver on the internet,you can go to the shop and ask for the driver CD
If those doesn't fix your problem,give me the detail series of your camera and i'll search the internet for it :-)
using this link you will be able select your
drivers
you will need to open up
your network connections click start control panel network connections this may
vary depending on your operating system look for local area connection if you
see a red x or a yellow exclamation or question mark you will need to update or
install the driver or it could be firewalled
If you are trying to
connect through a modem/router the driver should have come with a disc provided
by your ISP internet service provider or your motherboard disc
you might have to connect
the usb lead to your modem to get a connection then
administrive tools computer management device manager scroll to network
adapters should see a yellow question mark? right click install drivers if you
cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html
Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don't have or cant find your land
driver hope one of these will help you
well, sorry for the slow reply, got stuck with filming+editing and used another sony camera which is fine..tried the above but couldnt find the driver, i dont think its installed at all...i bought the camera from abroad and someone send it to me! so cant get to a store+the cd has only manual..so i assumed win7 will connect it automatically like z1..if its any help and you can lead me to the driver online the camera model is sony HVR-z7u
