Washing Machines Logo
Posted on Aug 22, 2012
Flashing lights I have an Indesit Wixl125 washing machine. I started the wash cycle but the "door lock" (flashing rapidly) and two other function keys are flashing and the cycle wont start?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3494
Points
12
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
5 Related Answers
cluedo
  • Posted on Jun 10, 2008
SOURCE: Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Anonymous
  • 1294 Answers
  • Posted on Apr 02, 2009
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Anonymous
  • Posted on Oct 15, 2009
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Anonymous
  • 8619 Answers
  • Posted on Feb 18, 2010
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Anonymous
  • Posted on Apr 19, 2010
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Hi my indesit innex when it get near the end it's stops and lights start flashing. Most of the lights are on and flashing but the main one is the lock door button flashing.
The issue with the Indesit Innex washing machine near the end of its cycle is causing the lights to flash and the machine to stop. The main light flashing is the lock door button. To resolve this issue, try the following steps:
Check if the door is securely closed. Ensure that the machine is level and not tilting. Verify that the drain hose and pump are not clogged. If the issue persists, consult a professional for repair or service.
Start/pause light flashing green on Indesit washing machine but none operational
Try cutting the power again for 10 minutes. If it doesn't fix it, you will need a service call.
1helpful
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Indesit washing machine function lights ruppidly flashing in the middle of washing cycle
Possible that the inlet filter or the valve is blocked and so there is no or less flow at the time of rinse cycle. Please remove and reset the valve.
click on : Inlet valve.
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
6helpful
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
