Xitel Inport Hotwire Logo
Anonymous Posted on Aug 22, 2012
Hotwire does not open
I am running 64-bit Windows 7 Home Premium on an ASUS laptop. I am trying to record from cassette to my laptop. Before the recovery I just did on my computer, Hotwire would open immediately after I plugged the USB into the port. But, since I did the recovery, which is basically a reinstall of the whole system, Hotwire will not start. The computer makes a sound when it's plugged in or removed from the USB drive, but nothing else happens. How can I make the computer open the software? Thanks
  • 1 more comment
  • Anonymous Aug 24, 2012
    Hotwire used to open automatically when I plugged the usb cable into the usb port. But it doesn't open at all since I did the recovery on the computer.
  • Anonymous Aug 26, 2012
    In answer to the email I just got, "No the problem is not solved." I don't see where to click "No". I've said everything about the issue in the above two comments. Thank you.
    I mean I said everything about it in the last two comments on Aug. 25.
Axiom Media Support
Level 3:
Master:
  • Master 409 Answers
  • Posted on Aug 24, 2012
Axiom Media Support
Master
Level 3:
Master:
Answers
409
Questions
0
Helped
116180
Points
1269
What kind of 'recovery' did you do ?
If you did a 'factory recovery', then you will likely have to re-install the Hotwire software before it will recognize the device.
  • 6 more comments
    I thought that might be the problem. But I can't find an installation disk for Hotwire. I don't throw away installation disks,... but it appears I may have this time. Can I get a new installation disk?
    I did a factory recovery.
  • Axiom Media Support
    Axiom Media Support Aug 24, 2012
    the best source for drivers is from the mfr's website....though their may be copies of it elsewhere on the internet.
    according to their website, there is no disk, the drivers are in the device itself. When you plug it in, go to the device manager [or Sounds in control panel] and see if it is listed. Set it as the Default audio device.
  • Anonymous Aug 25, 2012
    In the Sound dialog box, I click on the Recording tab. INport Hotwire is listed among the devices, and it is the Default audio device. In the Recording tab, I went to Properties > LIsten, and checked "Listen to this device". So it now plays the music through the computer speakers. Also in the Recording tab, there's a field that says "Device Usage: Use this device (enabled)". So the only problem is the software application does appear, and I can't do anything with it.
    Oops, I meant, "...the only problem is the software application does NOT appear..."
    Axiom Media Support Aug 29, 2012
    does the software appear in the list of 'all programs' on the Start menu ? If so, then you should be able to launch the app manually
  • Anonymous Aug 30, 2012
    According to Xitel support, there was an installation disk for the software, and I no longer have it. But it turns out that any digital recording software can work with Hotwire. So I downloaded such an application, and I'm back to digitizing my recordings. Thanks everyone for the assistance.
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
2answers
Printer prints a faint offset ghost image
File name:s.gifHPPDU.exe [1/1, 1.54M]System requirements:s.gifNo additional prerequisitesReleased:s.gif2010-08-13Version:s.gif3.0.0.013Compatibility:s.gifMicrosoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XPFix/Enhancement:s.gifThis version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
2helpful
HP IIP printer prints spaces where ink should be. Letters are incomplete, jumbled. A fixer problem??
2answers
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
2answers
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Hi, i have an HP printer D5160 and the desplay shows the err 03 31 if f4 dd6 and i can't print anything Thank you Aris T.
1helpful
My printer will not print black ink i just changed 3 cartridges
1helpful
My D7160 cuts the bottom part off of every photo. How do I fix this?
Will not print. Have to power off and then power back on for printer to start.
Top Xitel Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Xitel Audio Player and Recorder Expert? Answer questions, earn points and help others
