Casio FX-115ES Scientific Calculator Logo
A
Anonymous Posted on Aug 21, 2012
From fractions to decimals in casio fx-115es plus
4 Related Answers
k24674
  • 8093 Answers
  • Posted on May 25, 2010
SOURCE: I cannot find how to change my answer display to a...
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Outpout mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
  • 102366 Answers
  • Posted on Oct 29, 2010
SOURCE: How do i convert fractions
To convert a single result to decimal, press the S--D key. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Anonymous
  • 41 Answers
  • Posted on Sep 15, 2009
SOURCE: changing fractions to decimals
pressing the 'a b/c' key toggles between fraction and decimal formats
  • 102366 Answers
  • Posted on Nov 08, 2010
SOURCE: how to change casio calculator into decimals,my
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Casio FX-115ES plus decimals to fractions
The display of radicals and Pi is limited. For example only square roots are displayed as roots, standing alone or in some complicated fractions. Pi is shown as Pi, but pi^2 is not. These are limitations you have to accept. So you did not do anything wrong.
1helpful
Can a casio fx-115es reduce fractions
Yes. Simply enter the fraction and press =. If the calculator is in the MathIO mode it will display the fraction in its simplest form. If you're in the LineIO mode, press the S--D button to convert the decimal to fraction.
1helpful
When ever i type a dec on my casio fx 115es it keeps giving me a fraction and i dont need a fractions this problem has just started
To convert a single value from symbolic to decimal form, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
7helpful
I need a caculator that you can change a fraction to a decimal
On the fx-115ES, to convert a single result to decimal press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
8helpful
How do i convert fractions to decimals on my casio FX-115ES calculator?
19helpful
My calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
1helpful
How do I convert decimal to fractions on my Casio fx-260?
You can't or fractions only or the answer will be in decimal. sorry
1helpful
2answers
Help with my casio fx-115ES please??
Press [SHIFT][MODE] to open SetUp. Select [1:MathIO]
To convert a fraction to sa decimal and (maybe) convert back to fraction, use the [S<>D] key.
3helpful
2answers
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
8helpful
2answers
When I divide, it turns the answer into a fraction. How do I get back so the answer will be a decimal? With a Casio fx-115 ES
Press the S<>D key, (located right above "DEL"). This will shift the answer from fraction to decimal. This sounds like a pain but having both functions available can be a big plus.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
