Too late....instruction data was compromised and you may have lost DLL facilities to restructure your existing code. The only solution is to try and back up the files you want to save and copy them to CD/DVD or flash drive. Reformat the computers hard drive and establish a fresh Operting System.
install your sound driver, on MY Computer right click then properties then device manager, check if your sound card is not yet installed, then find the cd driver that comes with your pc, after that install the driver of your sound card from the cd, if you lost the cd download cpu-z to determine your sound card then download it online, or to its respective manufacturer
Hello
No i doubt the beep will go away if you format.The beep or beeps are trouble codes,a warning something is not right.
Usually related to the cpu,memory sticks,or a video or sound card on the motherboard.or a issue with heat.
Check your motherboard manufacture websight for the codes.Usually a set of short beeps is memory.
Try taking the memory sticks out and reseting them back in.
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry. After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Have you tried to reformat or wipe out your computer? If not I would go ahead and do this with a clean installation of the OS. If it continues to act up , then you definitely have a hardware issue.
Please post back after you do this or have done this already.
Hello.
1st Did you reinstall the sound card drivers?
they can be dowloaded from the manufacture websight.
2nd Is sound devices listed in device manager.
If not, you may need to remove panel from cpu unplug pc first.
Remove sound card and install it into another open slot.
If slot is not available put back into original slot.
