U cant change channels unless the mic is keyed up. the radio will transmit on one channel and then when u unkey it jumps to another channel to receive. the fixed channel button is turned off pls help me!!!
Look at the mic gain/ rf knob and push mic gain knob in (it's a on off switch for the dw feature) there is a led indicator under the channel display to let you know if the dw feature is on or off. When off it will no longer transmitt on one channel and receive on another channel.
Common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
SOURCE: Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
SOURCE: Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
SOURCE: galaxy 44v no transmit or receive
Try replacing TR41 (2SA473).
Also check TR40 (2SC945), D78 (7.5 volt Zener Diode), and D79 (KB 262).
[email protected]
SOURCE: My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
