Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
these are hard to do. it needs to bend the tabs and pull out staples,then remove links and bend back, these are a pain in the ****. can be done by experanced guy. i can do them 10-15 dollars
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist. If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be.
Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
IF they still make the same bracelet for your watch you will be able to buy a replacement. If the watch is a leather strap then it is much easier as I can guarantee they will have a compatible strap. Contact citizen to see if they have any metal bracelets or leather straps for this watch.
