Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The other night I call your tech on line to get my wireless
router back online for a one time fee one of your tech’s reconfigured the
router. At this time the router works, but when I power up my computer I have
to go to the easy set up to get going. What advise can you provide to me.
SOURCE: Linksys wiereless notebook adapter WPC 54G
this model as the Intel® PRO/Wireless 3945 802.11 a/b/g built in.
SOURCE: WRT150N looses wireless connectivity
Change the Channel mode from mixed to B-G only....u bought a new N series Router ....thats something gr8..but ur NIC are still on B-G Technology compatible....so either to need N series NIC or u need to configure ur linksys to B-G mode only...so that it will resolve the compatibilty issue from ur NIC.....Hope ..u will be able to do it...or u can take the help of linksys to fix it in this way
SOURCE: Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
SOURCE: Moved router to connect directly to the Comcast
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
