Question about Leisure Cookmaster CM101NR
Left hand oven and clock not working on cook master 101
Left hand oven and clock not working everything else ok
HOW TO SET CLOCK ON MIELE H806 OVEN
On the control panel: Beneath the label "Cooking Time," press the "Duration" and "End" buttons simultaneously and hold using your fingers on your left hand. An arrow will display above each button.
Using your other hand, rotate the knob to the left of the panel to adjust/set the time one direction or the other. Once set to the appropriate time HH:MM, release your fingers from the "Duration" and "End" buttons.
The time is set.
Jul 22, 2012 | Zanussi ZBF660 Electric Single Oven
My oven door will not open
Un plug it or disconect it and then switch on again
Sep 18, 2017 | Electrolux ICON Microwave Combination Oven
I have a LEISURE COOKMASTER 101, it has a clock with buttons below that include a BELL, COOKING POT , STOP , PLUS and MINUS button below it. It has on the left a grill/oven at the top and an oven below...
Hello would you happen to have a model number or any serial number on your LEISURE COOKMASTER 101 I will be trying to obtain your specific manual and not provide one that is generalized and these numbers help to locate your exact unit. Thank you I await your reply
Rick
Oct 28, 2011 | Refrigerators
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
We were cooking a dish and stopped it at the mid point and to add some sauce and it would not restart. Clock and everything is out. Everything esle in house works, no circuit breakers were off. The Jenn...
The same thing happened to ours last night. We went to add another minute of cooking time and realized the oven was dead - no clock, no display of any kind, and no more cooking!
I've verified the power outlet is OK. Ideas???
Feb 19, 2010 | Jenn-Air M170 Microwave Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
ONE OF THE OVEN DOESN'T WORK,
Yes the clock needed reset, by pressing down the stop cook and start cook buttons together, then +/- to the 24 hour clock time. then it works!
Sep 10, 2007 | Ovens
Left hand oven
The left hand oven needs a new flame failure device fitted , it is a normal oven not for slow cooking . This repair can only be carried out safely by a registered Gas Safe engineer . Visit WWW.gasSafeRegister.co.uk or ring freephone 0800 408 5500 to find one in your area.
Jun 02, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Problem with clock and Auto setting
hi, we've sorted it now, we just pressed the buttons very hard....
Apr 05, 2007 | Rangemaster 110 (Gas) Kitchen Range
Leisure Cookmaster CM101NR Logo
457 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
