My machines is canon ir 3300 is showing error code e000803-0000 pls tell me a solution.
Similar to
Description
The 24V output from the composite main power supply PCB is absent for 1 sec or more
Causes
The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Remedy
1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
SOURCE: canon ir 3300 display shows error E000003-0000
RESETTING CODE E000003-0000 ON CANON IMAGE RUNNER 5000 COPIER
