Yes anything with a core 2 duo should work. The only requirement that I'm aware of is 64bit processor and Core 2 Duo is just that. Now if it was a Core Duo (or Core Solo) this would not work.
If you have the system install DVD that came with the computer, put it in the drive and restart. Immediately after the startup chime, hold down the option key. You will see a hard drive button appear on the display. Wait a little longer, and you should see one or two more buttons for the System Install volume and possibly the Hardware Test volume on the DVD. Click the System Install volume, then the arrow button. When the system is finished startup, do not start system install. Go to the File menu and select "Reset Password," then select your user name from the list of accounts shown (note that it may be the Unix shortened version of your user name, with no capital letters). Enter a replacement password as directed, then restart.
MAC OS X can work in Intel computers but it might need to be cracked to install, In my opinion try dual booting your computer this mean making another partition on your hard drive to install MAC OS X to for the time being to see if it will work on your system and hardware
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
You will need to format the drive to work with you Mac.
3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon.
NOTE: For devices with 2 or more hard drives, please review the configuration settings to determine which volume type works best for you.
9. Click OK.
That means the hard drive has gone out or the controller for it. You could take a chance and replace the hard drive or if you have a the warranty on the unit have apple fix it.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed:
1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
