Computers & Internet Logo
Posted on Dec 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Video card not working with xp sp3
I am running a 9600pro dual boot with xp sp3 and vista. For some reason the video card does not work with xp sp3. If I install the ati drivers for the card xp wont boot, however it will boot if i use the generic drivers that come with xp.
The card works fine in vista and its worked on previous versions of xp.
  • sannw100 Jan 31, 2009
    I have the problem when i finished install xp 3 . it is errors of audio device on high definition audio bus & VGA compatible.
  • chazchaz Apr 16, 2009
    i have the ge force fx 5200 and it ran fine with xp sp2. I just installed a new drive with xp home sp3 and any video pyaying hesitates or doesn't play at all. Something is affecting the refresh rate, i left a message at ega home # but no one has called me back, please advise
Anonymous
Level 3:
President:
  • Master 1,179 Answers
  • Posted on Dec 20, 2008
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422678
Points
3751
The drivers for XP and Vista are different. You will need to install the drivers for XP as well as Vista for dual boot operations. Make sure you install the XP driver in the XP partition and the Vista Driver in the Vista partition. This should solve the problem.
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Blue screen of death.
You might try setting the display adapter in the bios to PCI-X,
You could also try going into safe mode to see if you can install the new drivers and fix the problem.
Other than that you would need to stick the card in another computer and confirm whether it is functional.
I have the exact same card with Vista and had no issues, and have been very happy with it.
1helpful
Not recognise network card
Get the SP2 back since you have worked with that well. If the win Xp still suggest for updgrade to Sp3 express you can ignore it anyway. Just click cancell to any install command from the XP SP3 xpress.
Hope it might help you.
2answers
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
2answers
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
4helpful
2answers
ECS 761GX-M754(V3.0A) Motherboard, No Graphics Acceleration in Xp
Were the correct drivers installed into XP.
It seems to me no video drivers are in XP and you are running on the windows ones
3answers
SOUND CARD
you have laod sp2 .sp3 is no sound it is some problem in sp3 ..........
Grand Canyon Tech
Grand Canyon Tech
