Cars & Trucks Logo
Posted on Aug 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kilometers to miles perhour - xB Scion Cars & Trucks
ZJ Limited
Level 3:
  • Scion Master 17,989 Answers
  • Posted on Aug 21, 2012
ZJ Limited
Scion Master
Level 3:
Answers
17989
Questions
0
Helped
14456316
Points
60858
Hi there:
To Convert km to miles just keep in mind that 1 kilometer = 0.621371192 miles
20 Km/Hr = 12.427 Miles/Hr
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Kilometers to miles
Multiply kilometers by .6 example '100 kilometers is 60 miles. I always figure so many kilometers and multiply by .6.
If you go 30 kilometers and want miles you figure 30 times .6 equals 18 miles.
Hope this helps.
How do you convert kilometer to miles per hours
A kilometer is .621 miles. Then just x. Example driven 10 kilometers. .621 x 10= 6.21 miles
1helpful
How to go from miles to kilometres on my bmw 320d
A mile = 1.613 kilometers. To find kilometers, multiply the miles by 1.613.
A kilometer = .62 miles. To find the miles, multiply the kilometers by .62.
3answers
Chugs when going going between 25 to 45 miles perhour and uses 1/8 of a tank of gas in 50 miles.....
needs a tune up-plugs, air filter, fuel filter, fuel injector cleaner-cheers denny
Convert 1 mile to kilometers
One statute mile is 1.609344 kilometers. One nautical mile is 1.852 kilometers.
2answers
I have a Canadian car with the odometer reading in kilometers how do I figure out odometer reading in miles
Here is an example of miles to kilometers
mi -> kmkm = mi * 1.6093km = 107.098 * 1.6093km = 172.36
or kilometers to miles
km -> mimi = km _______ 1.6093mi = 107.098 ________ 1.6093mi = 66.548
2helpful
2answers
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
1helpful
2005 cts @ 100,000 what service needs to be done?
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - EXHAUST SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - AIR CLEANER/ELEMENT - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL FILTER - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - SPARK PLUGS - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - TIRES - ROTATE - [Tires should be rotated every 5000 to 8000 miles, and/or at maintenance I or II service intervals.Check tire pressure, thread depth and wear.]
Top Scion Experts
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Scion Expert? Answer questions, earn points and help others
