SOURCE: Same problem as above.Disney p1310ATV lost the
there may be a problem with the tvs remote sensor. most universal remotes you dont even have to enter any codes you just have to follow the same steps to enter the code but instead of entering a code all you have to do is press the channel up button after following all other steps, just keep pressing up until it turns the channel on the tv then press enter or similar button after it changes the channel and this should lock in the code without entering a specific code.And if all other remotes only half the buttons work on if it happens with every universal remotes then it probably a problem with the remote sensor or the tv . Good luck too ya!!!
SOURCE: I can't get all the channels using the remote
I enter the menu button, channel, add, and it begin to add the channels for cable.
SOURCE: where is the input button on the remote
Try channel 999 or go backwards from 0. Some TVs work like that to get to the aux input.
SOURCE: disney dt 1350-c 13
These were made by a variety of people for disney
On the back should be a label with more details and numbers etc. try posting them back
