The tank fills with water 3-4 times a day which is great but the air blowing out is so hot that it heats up the room and feels like it's actually making the room MORE humid.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
A dehumidifier is the same thing as a window unit air conditioner that you sit on your kitchen floor instead of installing it into a window. It will blow cold air out one side (evaporator side) and hot air out the other. (condenser side) Hot/Cold cancelling each other out, (plus a little bit of "extra" heat from running the thing) yet the evaporator STILL removes humidity from the air in the form of a puddle of water on your kitchen floor. They (air conditioners & dehumidifiers) are both essentially air conditioners only difference being is that in order to "cool" an area, the "condenser," or "hot" air would have to be moved outside somehow. Air conditioners do not "cool" air, per se. Instead, they ABSORB & MOVE HEAT from one place to another via some type of gas (freon) and a compressor pump inside of a closed tubular system. (copper,brass,aluminum, etc)
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in. You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
Dehumidifiers are designed to remove the moisture from the air not to cool.
Unfortunately, the way they remove this moisture is to reheat the air to
further dry it after it releases its moisture. Basically, the room
temperature humid air enters the dehumidifier where it is cooled to its
dew point which results in its releasing its moisture. This dried air is
then heated by the combination of latent heat of condensation, which is
a natural result of the process, and by circulating through the
condenser where heat is exchanged from it to the air. The result is the
air going back into the room will be slightly warmer than it was going
in, usually around 2 to 5 degrees.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket. I out mine over the floor drain. Turn off and it will defrost over night. Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter). Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water. So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The
'coil' (a finned metal part that needs air to flow across its surface) may be filled
with dust and obstructions, so no air can move...then no water. There is a
blower motor that must move the air. If it is seized up and not blowing
air...very little or no water. The compressor creates condensation from
air moving across the coil (like the moisture than forms on an ice filled
working.
Dehumidifiers and how they work Heat pump dehumidifiers
Dehumidifiers use a heat pump (similar to an air conditioner's heat pump) or chemical adsorbents to remove moisture from the air without cooling the air.
A heat pump dehumidifier uses a fan to draw indoor air over a heat exchange coil. The coil is almost freezing. The water in the air condenses on the coil and is drained. A second heat exchange coil reheats the air, which the dehumidifier exhausts into the room.
A heat pump dehumidifier dumps heat lost from the compressor and fan motors into the air. It returns to the indoor air the heat generated by the dehumidifier turning water vapour to liquid. I got this off the internet
