***hi there,ill be willing to help you on that. ****
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3.
Press the Stop button. The print head moves to the
position to indicate which cartridge is low or expended.
4.
Press the Stop button again.
If another cartridge is low or expended, it moves to the position. Press the
Stop button again to see if more cartridges are expended.
If no other cartridges are low or expended, the print head moves to the replacement position on the right.
5.
Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7
Remove the cartridge from the package
8.
Remove the yellow tape from the bottom of the cartridge.
9.
re
Insert the new cartridge into the holder and push it down until it clicks into place.
10.
Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner..
11.
Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
The printer responded when I pressed and held the stop button a second time. Thanks for the advice.
need to change ribbon; carriage will not stop in proper position to do
this solved the problem .
all my lights are blinking and the printer doesnot work, it is epson cx7400. can anybody help me please
