Welll my phone had died and i came home put it on the charger and turned it on and it said pin blocked call customer care. How do i unblock my phone. i recently brought a phone from someone i know and i came home and turned it on and its sayin inactive sim or limited service on every sim i put in, is dere a way i can solve this
SOURCE: unblocked fone now saying limited service when putting new sim in
i have a samsung sgh G600 and it from uk and i live in India and when i put my indian sim it asks for network lock
SOURCE: I can't get my phone to work. It says its "pin blocked"
If you entered a pin code under the security option in phone settings, you will need to enter the code in order to unlock your phone. If you can't remember it, you can go to phone settings and under security, restore factory settings. You will need to select Restore and Clear. You will lose all your phone numbers, and personal settings but the phone will revert to the way it was when you bought it. Good Luck.
SOURCE: my phone is pin blocked and i dont know how to unblock it. help
in order to unlock your PIN you need the PUK (Pin Unlock Key).
This information can only be provide by your carrier.
If this is a card you bought with the phone then the PUK code should be in the document where you initially got your PIN from.
If it was a bundle Phone Sim Card then there is also a chance to be on a sticker outside the telephones original box.
However the simplest way is to call your carrier, they will give you the code right away.
Hope it helped.
SOURCE: my screen says PIN blocked,
Personal Identification Number is all thru simcard... check if you kept the PUK or the PIN unblock code,just enter it...otherwise,you need to request retrieval on you service provider.
i just bought a samsung g600 and it is blocked when i turn it on it says limited service how do i unblock it
unblock my phone.
