SOURCE: 2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
SOURCE: wiring diagram 354xi kicker amplifier
do you need the internal schematics, or how to hook it up? let me know.
SOURCE: kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
SOURCE: my kicker zx series 1500.1 has no output thru the speaker ports
ck ext fuses, then possible internal issue
SOURCE: my kicker amp zx 300 want turn off when i turn my
it was just what u said so had to buy new amp thank u dudes are great darryl
