My Samsung fridge SRS583HDP is making loud humming noise, seems to be coming from the back. Noise stops when I open the fridge door but starts again when door is closed. Annoying humming noise can go on for 1/2 hr continous!!
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
SOURCE: fridge has just started making loud noise and temp too high
sound like that you have a ice build up thats hitting your fan blade. Take and do a manual defrost on the frig side and be extra careful removing the cover in the back because there's 11 screws that have to come out before trying to remove the back poanel. Also if theres stillo ice in there what happens is that when you try to pull the back panel off it breaks off the stryrofam that samsung used for the air paths to cool the frig. so be extra carefull removing theses and if oyu do tear any and the airflow is not going the corect way you will drive yourself bonkers always defrosting htis unit. so heed my warning on this particular unit. its a great unit if you can psture what has to happen for the air flow to be correct. also put all of the screw back in correctly on the panel too. don't skip any because then the air flow is compromised. Good Luck and don't forget to rate the answer please. Haooy Neew Year!!!
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
SOURCE: fridge sectipon of fridge freezer started making a
Replace the fan motor or at lest take the cober off and cneck to see if there is ice build up or somthing has got to where it hitting the blades.
