All HD, Power inidicators normal; moving screen sometimes it goes black but returns to white again
Regarding ; White screen , I flipped my notebook over and removed the power source(s) , power cord and battery. I then removed the three screws in the battery cavity and the two outside corner screws to gain access to the connection for the LCD and found a loose connection. It seems that the wire that connects to the screen was being moved every time I opened and closed my computer. So very glad to find that bulb and inverter board was not bad. Prior to this , I did try external monitor and found that all was okay as far as operation of start-up.
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
SOURCE: how to fix compaq presario cq60-215dx black
With the laptop turned on, shine a bright light onto the screen. Can you see anything on the screen (like windows log on screen)? If so, your inverter has failed. This can be replaced relatively easily. Please post back with the results of the above.
Zahc
SOURCE: MY Compaq Presario CQ60 HAS A
Try using your FN key or your funtion key and f4 key some computer it is f6. This will make sure that your don't have it in Projector mode.
SOURCE: My Compaq presario CQ60
Connet it to a flatcren before firing up to solate the issue Replace the lightning tubes cost 60 usd Goog luck Rene
