Few days ago a vertical black line popped up on my Samsung plasma tv on left side. Please help me to fix it. Thanks (model # PN50A450P1DXZA)
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
SOURCE: samsung 50
I have the same problem. No video just audio.
No on screen display visible either (volume, channel labels) nothing.
Samsung tried to repair this under warranty TWICE within 2 months. Second time they replaced circuit board and it worked for another 8 months. So I paid $1.500 for a TV that died again after 1,5 year - this is ridiculous.
I have no idea what the reason might be and I wont try to fix this since samsung tech could not fix it without replacing circuit board.
SOURCE: Samsung TV bought in USA PN50A450P1DXZA can we
I dont think they have the same output voltage.
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
SOURCE: Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: I have a samsung plasma
Did it come this way? If so I would recommend returning the TV. I'm guessing you have tried using different channels, inputs, etc. If not please do so to determine if it might be specific to an input or channel. This is not something that someone will be able to talk you through via message boards. I would first try calling the manufacturer and then the retailer if you continue to have problems.
