I just want to reset it back to factory settings, in recovery, my other laptop is easy 2 buttons u get everything back just cleaned up this one is making me backup and sytem image and everything? HELP
HP Compaq 6510b PC Notebook
HP Notebook PCs - Overview of Recovering the OS or Reinstalling the
Operating System (instructions to do every type of recovery on any operating sys.): http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=3355650&prodTypeId=321957&prodSeriesId=3355650&objectID=c00006110
Resources for HP Compaq 6510b Notebook PC (all info including the manual, drivers, guides, for your comp): http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3355650&exit=product_series_oid&jumpid=reg_r1002_usen_s-001_title_r0001&lang=en&cc=us
all info from a search for 6510b on hp.com
SOURCE: Error 0x400 100 130000 1002 while restoring factory image HP
I am assuming you are trying to reinstall Vista. Apparently, HP's recovery partition is less than perfect and the recovery disc you created is probably worthless. (and you can NOT make another one, they only let you make one!) You are not the only person to have this issue.
Here are some things you can try:
1) Borrow an OEM version of Vista from someone...anyone. It sounds like you are proficient with PC's and maybe you know someone who works in IT. Use your product key (25 digit key code) and you should be able to reinstall.
2) if you like Vista, buy yourself an OEM version. It will not have all the factory (HP, Dell, Acer, whatever) BS on it. It will positively work because your hardware if fine.
3) Put XP on it. Personally, I think Vista is a mess. Microsoft is working on "OS7" and soon Vista will be like "Millennium".
Sorry it's not an easy fix, but glad your hard drive and memory show no errors.
SOURCE: reset factory default HP Mini 1035NR PC Notebook
SMART measures physical attributes of the hard drive. Reformatting won't help that. A bad SMART status alone doesn't mean your drive is failing, but combined with the delayed writing failures and the slow speed, I'd replace it ASAP.
SOURCE: hp pavilion dv9000 screen and factory settings
*Actually*, with regards to the screen issue, software CANNOT cause a failure when the display assembly is physically moved....The two possibilities are the LCD harness (video cable) part# 432962-001 OR the actual LCD itself (part# LP171WP4 (TL)(03) for most models). My money's on the cable, not a stupid driver...
SOURCE: Please Help with a system recovery on a HP pavilion a1253w!
The reason the cd recovery did not work is that it was made for some other HP model.
On the unit you are trying to recover, reboot the computer and press F10 . several times. You should see a recovery menu. Select the type of recovery that will format and recover the unit to OEM defaults.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: HP Pavillion WebCam Unknown Device (Not Working) plz help !!
sounds like that particular webcam isn't compatible with vista.
SYSTEM RESET
Warning - You may loose all of your saved files - Back-UP first!!
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you may loose all of your files and after market downloads.
Back-UP first!!
That's worth 4 thumbs up!
Click "Start" menu.
Click "Programs."
Click "Acer Recovery Management."
Click the "Restore" button on the bottom of the dialog box that opens.
Click "Restore System to Factory Default."
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Click "Start" to restore the computer to the default factory settings.
Click "Start" menu.
Click "Programs."
