Canon PIXMA MP210 Photo All-In-One Printer Logo
Posted on Aug 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where are the "ink absorbers"?
Error says "Ink absorbers" are full.
  • larry_olson
    larry_olson Aug 22, 2012
    Couldn't see what were the ink absorbers. Dabbed around the left and right ends of the printer slide and got a lot of old ink but it didn't help. Had to take the printer into a repair shop.
Anonymous
Level 3:
  • Canon Master 32,281 Answers
  • Posted on Aug 20, 2012
Anonymous
Canon Master
Level 3:
Answers
32281
Questions
Helped
7907480
Points
102259
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
5 Related Answers
A
Anonymous
  • Posted on Apr 30, 2008
SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
Anonymous
  • 52 Answers
  • Posted on Jan 05, 2008
SOURCE: Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Anonymous
  • Posted on Dec 06, 2008
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
my printer say, "the ink absorber is full".
nyilasrobert
Robert Nyilas
  • 627 Answers
  • Posted on Jul 08, 2009
SOURCE: I keep getting an error message that the waste ink
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Sep 06, 2009
SOURCE: canon pixma mp160 ink absorber is full
e75ff09.jpg this the reset wast ink please follow it step by step
5helpful
"ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
I am unable to copy, i keep getting the message "Unable to print 36"
The error message is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
1helpful
Ink absorber full - what do I do
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Use MPTOOL to reset your mp160 waste ink full
download mptool http://www.ziddu.com/download/8524406/MPTool.rar.html
But before your use MPTOOL get manual guide how to use that MPTOOL
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help....
3helpful
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Ink waste absorber is nearly full. What do I do?
You need to reset it.
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Ink well transformer full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Absorber tank is full
1helpful
2answers
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
old marine
old marine
ZJ Limited
ZJ Limited
