I just screwed in a new filter and now it leaks all over the place. If I put the old filter back in, no leaks. The new filter looks fine. . . seems to look the same as the old filter except the interior piece is yellow instead of white. HOW DO I FIX THE LEAKS?
MAKE SURE THAT WHEN YOU REPLACE THE FILTER IT IS IN THE SAME ORDER AS THE ONE YOU REMOVED OR THAT IT IS THE SAME MODEL TYPE REPLACEMENT , I WOULD TRY TO TURN IT AROUND FIRST , A THIN WRAP OF "WHITE PLUMBERS TAPE" , AROUND THE SCREW TOP INNER SEAL MAY CORRECT THE LEAK , ABOUT THE FILTER , WELL , IT MAY JUST BE SIMPLY IN THE REVERSE ORDER , TRY TO FILP THAT OVER , AND WHEN YOU RESEAL THE CAP ON THE FILTER MAKE SURE THAT THE SEAL IS ON PROPERLY , APPLY PLUMBERS TAPE ONCE AROUND , AND *"BEFORE YOU TIGHTEN IT" , GENTLY , REVERSE THE CAP BACKWARDS , SLOWLY , UNTIL YOU FEEL IT "SEAT " PROPERLY , "THEN" YOU MAY TRY TO RE-TIGHTEN IT . THIS SHOULD REMEDY YOUR LEAK , IF IT CONTINUES MAKE SURE THEN THAT YOU HAVE THE CORRECT REPLACEMENT FILTER MODEL FOR YOUR PARTICULAR ITEM . HOPE THIS HELPS YOU . NOW GO FIX IT ! GOOD LUCK .
SOURCE: GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
SOURCE: I have a GE dual filter smartwater system (yellow
To stop the leak you need to make sure that the o-ring is in place where you thread on the canaster. If it is there and it steel leaks then wrap the threads with teflon tape.
Good Luck
