Its new out the box and the full charged green LED light came on since i plugged it in. I let it charge for 18 hours. When i take it off the charger it doesn't do anything, not even turn on.
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
SOURCE: have an e100 razor electric scooter. it has not
The batteries are dead. The battery in these scooter need to be kept
charged or if not in use for a long time charged every 3months.
Otherwise, like what to you, they will go dead. The chemicals in the
battery have deteriorated to the point where it won't hold a charge.
Replacement batteies are available at:
razor.com
SOURCE: Razor E100 reset button and no charge
Yes the battery can go bad after so long of sitting. I would replace the battery.
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
