From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
SOURCE: Trying to install all in one printer X2600
The X2600 uses a #14 or #14a black cartridge.
Color cartridge is #15 or #15a.
Photo cartridge is #31.
Thanks for using Fixya.
SOURCE: my lexmark p707 with a
i bought a printer from a friend but i cant install it without a installation disk what do i do
SOURCE: Lexmark x3550 18C0032 ink cartrage set up.
The 34 and 35 cartridges will work. You can also buy a 23a or 24a from Lexmark.com and you can refill those.
SOURCE: cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
SOURCE: I cant find the ink cartrage on this printer to
I don't have your model Lexmark, but on my X4530 you have to lift the top scanning bed up, then the cartridges will settle to the middle for changing. Make sure you have the power on when you lift it, and you should see the cartridges in the middle of the printer. Good luck, hope this helps.
