Systems powers on, but screen does not turn on. Light on caps button constantly blinking. Can hear the fan running. Connect to external monitor, but nothing is showing. Did the reset procedure from HP, i.e Unplugged ac adapter and battery, press the power button for 15 seconds, plugged ac adapter back in and tried turning on, still nothing.
SOURCE: My satellite M55-S331 Toshiba laptop screen went black
cheap soma[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20soma%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]cheap soma[/url] zoloft and pregnancy[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20zoloft%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]zoloft and pregnancy[/url] ultram[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20ultram%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]ultram[/url]
SOURCE: monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
SOURCE: Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
SOURCE: Inspiron 1525..black screen. The screen is black
or screen probably is burned...
or inside crystals are broken..
u have to buy a new laptop
