Samsung GT-S5300 Galaxy Pocket Logo
Posted on Aug 19, 2012
Can't access wifi in my samsung pocket
Can't access wifi even if i'm already in a wifi zone, wifi turned on
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
663
Points
How i can access wifi on my phone
My wifi didn't works.
Keep backup of ur files nd contacts... it removes all...
- First, input secret code methode : Go to dial pad and type *2767*3855#
- Use recovery mode methode :
  • Turn off the phone
  • Press & hold volume up + home button simultaneously, then power on the phone
  • Release volume up + home button if recovery menu appear
  • Scroll down to factory data reset menu, use volume down to navigate and home button to confirm.
  • Phone will automatically restart and now the phone is on factory state.
Cannot connect to internet via wifi
try to turn airplane mode on and off and try it again or change the date on your phone to the current one
What to do if data network cannot be activated even if smartphone is internet and mms capable?
Try the configuration that's usually provided by your network provider.
Connect samsung pocket wifi
Samsung galaxy pocket doesn't has WiFi
WIFI router loses security settings after reboot & continual restart AP required
As far as I know, access points support Wi-Fi wireless communication standards through i have encountered such kind of problems like you. Maybe you can reset the Access Point from the very beginning, hope it will be done... And if you think it's necessary to know WIFI and Access Point better, there is an article for you" http://goodrouterswitch.blogspot.com/2012/08/what-is-access-point-and-how-to.html"
1helpful
How to configure pocketwifi
Quick Start Guide Introduction
Your Pocket WiFi™ Router sends out a WiFi signal so that you can connect to the Internet without the need for wires. Your Pocket WiFi™ links multiple WiFi enabled devices at any one time, for example your laptop, Apple® iPod touch, Apple® iPad or Nintendo DSi.
How many people or devices can share my connection at any one time?
Up to five devices can be connected. With increased users and high data downloading (i.e. streaming music) the speed may be slower.
Does Pocket WiFiTM work on Mac, Linux or Windows 7 computers?
Yes, Pocket WiFiTM with most WiFi enabled devices. The dashboard is browser based so works with any operating system.
Terms and Conditions
Check for PocketWiFi compatibility with the devices you intend to use it with before you buy. Device can operate with a maximum of 5 compatible WiFi enabled devices at ay one time. Unlocking fee applies. Broadband Availability: Broadband speeds are available in Vodafone's 3G Mobile Broadband Zone. Slower speeds can be expected outside Vodafone's 3G Mobile Broadband Zone. High bandwidth applications, such as video and music streaming, and full track downloads, only available in Vodafone's 3G Mobile Broadband Zone. Actual speed achieved varies depending on factors such as device capabilities, location and network usage. See www.vodafone.com.au/coverage for details. Vodafone Pty Limited ABN 76 062 954 554.
I can't access internet through wifi
Hi spatra279,
what is the model of your laptop?
1. Before you conect to the Wi-Fi, make sure that your computer has installed drivers for Wi-Fi.
2. Make sure that Wireless is already open or st-up.
3. Look for the Wi-Fi spot area or zone, if there's no Wi-Fi access on that area you may not connect to Wi-Fi.
Hope this helps.
Thank you for using Fixya.
Can't connect to the internet
If you want to connect to the internet, you have to find a free wifi zone. Now if have found a free wifi zone, Use this steps to connect to the internet.
  1. On your Nintendo DSI, Go to your System Settings.
  2. Search for " Internet " and click it.
  3. On the Next Page, you will need to click on Connection Settings.
  4. On the Connection Settings, Click on any Connection and tap the word None. If all the connections are already configured, click on any connection and tap the Erase Settings, this will erase the configuration for that connection.
  5. On the Next Page, click on the Search For An Access Point. This will allow your Nintendo DSI to search for wifi connections in the area.
  6. After the search is complete, it will list all the available wifi connections in your area, Be sure to choose the one with icon of an " Opened Lock "heifentrixx_12.jpg
Hi, This is Michael here. I have bought Samsung Wave S8500 in mid Oct 2010. I'm having a problem with my wifi & bluetooth too. I have upgraded the latest firmware. 1. Whenever i turn on the wifi in...
Hello ,
I have the same problem. It just happen lately that I can't use wifi and bluetooth in my Samsung wave. I tried factory reset and still, I have still that problem.
Thanks,
Leonard
Can I access the web using wi-fi while disabling the pay by kb feature on this phone?
Yes, once you turn the wifi on it should disable the phone anyways, which sends all internet communication onto your home wifi (Internet you pay for via dsl or cable)not the phone providers.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
