My control board is fried and i need to replace it. where can i purchase a new or refurbished board and how much do they cost?
SOURCE: Azimuth motor stalling missing the electronic home sensor
Check for binding in the gears; my 10" had aluminium chips in the fork base that jammed the gear. Cured by removing the RA manual adjust assembly - was useless anyway, as it could only be used with the RA unlocked. One setscrew in the fork base holds it in place,just loosen and pull up.
SOURCE: power problem on lx200gps telescope
If it's an electronic problem --- there are several folks on the Yahoo LX200 Group that can repair the board-- go there and ask for "RON"---
You should be using a stable 12 volt power source. The only other thing to check are
Get a temporary replacement for the hand controller and see if that works-- and-or get a low cost replacement hand controller cable from www.scopestuff.com and try the old controller with a new cable --- usually one of the capacitors is fried.
Meade is the only place to get parts---
See their web site for Customer Support--
www.meade.com
SOURCE: I need a new vertical lock for my ext-70at astro
From Meade--
See this web site:
http://www.meade.com/support/index.html
