When I insert a new SC card into the Kodak V570 camera, the camera tells me the card needs to be formatted. I say continue. It says it will erase all images. I say continue. The camera says formatting and then follows with the same two comments. I say continue and the cycle repeats. Any clues what I am doing wrong? Thank you.
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
SOURCE: I cannot format my brand new memory card in my Kodak Easyshare.
Believe the 4 GB card is too large for this camera and internal camera software was not designed to format or manage so much memory.. try a fast SD under 2 GB.
I would need to know if you are using the proper level card. Cheaper cards may not work in some cameras and high end cards may not work in low cost cameras. You may also have a bad card. try another and let me know.
