Hello, does anybody know how to open this device? Removing all visible screws from the bottom of device will not work. I have shorted the springs in the battery box because most of my batteries haven't fit. Now the device will not more working from battery though the 8 batteries have 13 volt (voltmeter) Thank you.
I have opened it. Behind the grill at bottom side are 2 screws (near the bass speaker). I failed to remive the grill, so I have drilled 2 holes in the grill at the positions the screws are. But unfortunately inside there is no damaged cabel, the device gets 13 volt, so what the hell is here going wrong? Why does the unit not work from battery after cutting the springs???
Unit is working again. Have bypassed cables from battery-pack to 24v input from power supply and added a switch into case. Now I can power on battery use from outside. If anybody needs pictures I can make some.
Hi Killerfisch. I'm also trying to open this case. Can you upload pictures? Thanks. Ben
there's a hex screw in the battery compartment
Oh, longe time ago! I have got it opend. removing alle screws from bottom side is the frist step. There are screws in battery pack - they are not required. On bottom side there are two additional screws behind perforated metal plate near the bass speaker. Taking a flashlight und you will find them. The problem is that these screws are unter the metal plate - so I have drilled 2 holes direct above the screws to accomplish the screws. When you have removed these screws it is very easy to open the case. My unit is working again and the sound of this device is fantastic.
