Heating & Cooling Logo
tony shaw Posted on Aug 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you add freon to haier window unit air conditioner
john johnson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 08, 2018
john johnson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5325
Points
All this talk about calling a tech is bull. You CAN handle and use freon (r22, r410,r134). All these types of freon do not require a special license or permit to use. EPA is not going to fine you for trying to add freon to a window unit. If you did this as a profession, I would say they might take a closer look at you, but they are not going to waste their time on one window unit, nor is it ill3gal to do this yourself. You will have to purchase a line tap in order to add the type of freon you need. Window units do not come with a service port. The tap will allow you to add the freon. Always add your freon to the low side of the AC unit, this will be the larger of the two copper or aluminum tubes going to the compressor. There will a label (tag) on the inside of the unit telling you which freon to use and how much. Also, you DO NOT need any certifications or licenses to purchase freon. R410a R22 R134 are all legal to purchase without the need for special certifications or licenses. California may have some laws on this, but most other states do not. I have been doing AC work for over 30 years.
  • Dii Kwadd
    Dii Kwadd Aug 07, 2022
    How does this post stay active? A neighbor can turn you in for servicing your A/C without a license. You pay $20K USD and he gets $10K of it. Check the laws and while throwing out very wrong information, take time to get certified where you can then purchase refrigerant legally and along the route, hopefully there will no longer be a need to make things up as you go.
Charles Dalton
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Aug 18, 2012
Charles Dalton
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
35814
Points
314
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
5 Related Answers
Anonymous
  • 10515 Answers
  • Posted on Jun 25, 2009
SOURCE: how do I add freon to my window air conditioning
My advise call a tech.
EPA performs random inspections in response to citizen tips pursuing potential cases against violators. The EPA is authorized to assess fines of up to $32,500 per day for any violation of the Clean Act regulations.
Always take a wise decision.
Thanks.
FunnyPlumber
FunnyPlumber
  • 43 Answers
  • Posted on Jun 23, 2009
SOURCE: How do I add freon to my central air conditioner
Adding refrigerant (Freon is Dupont's name for refrigerant) requires some special tools and gauges. More important than that is your system should not loose refrigerant. It you are low that means you have a leak in the system. It should be found and repaired before new refrigerant is added. A qualified repair technician should be called.
Sincerely,
Terry aka Funny Plumber
Anonymous
  • 56 Answers
  • Posted on Feb 12, 2009
SOURCE: air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
boomanfoo
  • 23 Answers
  • Posted on Jun 17, 2009
SOURCE: how do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Anonymous
  • 340 Answers
  • Posted on Jul 12, 2009
SOURCE: How to add Freon R407C to a ductless air conditioning unit
If you are not trained to at least charge a unit U will in the end do more harm than good get the proper service. what makes U think U need freon could just be dirty? Tom
3answers
Compressor not running.
Haier Air Conditioner Compressor
modernemporium.urizyme.tk/512124/haier-air-conditioner-compressor
Using a ohm meter, and the compressor is cool to the touch, and the ac is unplugged, Disconnect the wiring to the ... Failure rate on compressors so far not including. ...Haier 12,000-BTU Energy Star Window Air Conditioner with Remote ESA412K-L. Consumer complaints and reviews about Haier Air Conditioner. Since air .
Can freon be added to a window are conditioner?
This type of unit don't need much Freon but if it known leak yes fit it and add Freon as factory spec
1helpful
How do I add freon to Haier air conditioner?
Windows air conditioners do not come with service ports for checking or adding refrigerant.They are considered throw away items and you just replace them if they leak refrigerant.
How to add freon to a Haier hwr10xc6 Thru-Wall/Window Air? i accidentally damaged one of the copper lines & all the freon came out but i welded it back together put how to at it & where? help!
If the unit has no existing service valves you will have to purchase some - and braze them into the freon lines. Valves (with valve cores) can be purchased at a AC Supply house fairly cheaply and then you can braze them into the lines. One in the suction (big line that gets cold) and one in the liquid line (the one that gets warm). NOTE: be sure NOT to weld this into the 'discharge line' (one straight out of compressor).
Once you have the two valves welded into the unit - you can then charge the unit.
Good Luck!
I have to window units that are not blowing out cold air. the fan works. is there a way to put freon in them or do you have any suggestions?
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it. In order to add freon you must add a piercing valve to the low side of the system since most window units dont have service fittings
I have a small haier refrigerator and it needs freon. is it possible to add freon?
it leaked out some where, so the leak would have to be repaired first . consider the cost if worth it.
Compressure and fan not coming on, contactors pulled in from 24v .light blinks 3 times lps hps are jumped add freon still not working.
Sounds like your breaker is tripping for your outside unit. Compresser could be grounded out or a breaker problem.
1helpful
Window unit haier a/c (sorry, not sure model type, but it has a remote) isn't blowing cold (cool, but not cold) air and it sounds like the motor is just running in a 'fan' capacity. what can i do to get...
have your unit cleaned first, if it is cleaned and still the trouble persist. check if the compressor works. if not check the running capacitor for leak. if all are working fine have your unit system reprocess.
1helpful
How do I add freon to my hailer portable
you proably do need a piercing valve as those units usualy have no acces to the refrigerant. be carefull on how you do that the best way is to braze a fitting on and pull a vacuum then charge. most piercing valves will end up leaking on you down the road
1helpful
2answers
Where is the intake so that i can add more freon
most window units do not have service valves they do make quick taps that clamp on lines and pierce sor serviceing these units
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
