I don't believe there is a metal substitute for the stock part. I did not see one on the parts diagram and it is unusual for something like that to be offered as an option. BUT if the tool is jamming I suspect it is not due to the pusher. Make sure you are using the correct gauge (18 for this tool) nails first of all. Make sure you air pressure is adequate. Somewhere around 90psi would be the minimum. If too low of pressure is used it will not allow the driver to retract far enough to advance the next nail. If the tool is not leaking air anywhere then the last thing to check is to make sure the driver isn't bent. That can also lead to jams.
SOURCE: Describe your NT50AE2 2" Brad
Hi Randy,
Welcome to fixya!
Copy and paste this web address into your browser and a webpage will open with your nailer on it: http://www.hitachipowertools.ca/en/Products?cat=29&pid=254
Scroll down the page to the bottom of the description and you will see the owner's manual listed. Click on that and you can download and print a copy.
Please place a vote when you accept this solution. Thanks,
Handie Andie
