This fridge did this before, earlier this year....temperature raises in freezer and fridge, eventually worked fine again. is this a defrost mode? It lasted for about 2-3 days before working normally. This time its been about 24 hrs so far. It seemes to cycle, I can hear the fan running when I open the freezer. Coils are clean, just vaccuumed this summer.
Likely defrost mode, which on older models runs for a fixed amount of time whether needed or not.
The motor that times the cycle may be stuck or running slowly. It often is located at the bottom front of the frig behind a cover that runs between the front legs. Unscrew it and you will see a small motor running, that, through gears, turns a wheel 1 rotation every 24 hours.
The wheel can also be turned by a screwdriver - turn it until you hear a click that indicates defrost cycle is off. Should solve the problem short-term.
Long term, replace the faulty motor or clean it off to run smoothly. Alternately, unplug the motor so that defrost never kicks in automatically and defrost it manually.
SOURCE: Sears Kenmore ColdSpot Frostfree Frosting up/Not working
You have a defrost problem. You need to determine which one of the parts is faulty. The defrost timer on that model should be behind the kick plate in the center front underneath. If you turn the little knob by hand you will hear a load click when it gets to the defrost point and the unit should shut off. Check in the bottom of the freezer to listen for water sizzleing or for water running down. If it is the timer is not advancing and needs replaced. If not you will have to take the back off the inside of the freezer to see if it is the heater or the defrost thermostat. Unhook power before taking panel off or replacing any parts.
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
SOURCE: Refrigerator not cold as it
Hi, If you are hearing a clicking or buzzing then check out the last two tips. ''; '';
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
