About a week ago the NO SIM CARD indicator would appear. I would turn off my phone and after a few minutes turn it back on and the indicator would disappear. Since then the issue has been more frequent and now the NO SIM CARD indicator remains.
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
SOURCE: Sim Card
Stop!
The back does not slide off.
Use the small tool in the box to depress a very small plunger on the top of the iPhone 3G, next to the earpiece socket.
A drawer will open to insert your Sim.
Regards
Philip G0ISW
SOURCE: Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
