My Toshiba laptop yesterday shut down cold in middle of work. No lights. No sounds. Nothing. I several times unplugged it then plugged it back in but noticed that the power light would only occassionally flicker for split second; other than that ultimately nothing. In searching for answer, I am wondering if it is the system board/mother board. I hope not. Not strong tech person but am a DIY. I kept air circulatin around it because I know it has/had tendency to get hot. Any suggestions on getting it back to life? Thanks.
SOURCE: Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
SOURCE: Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
SOURCE: toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
SOURCE: Toshiba Satellite A55 Series S1063
The blinking power cord icon indicates that the battery is not charging, or is defective enough that it is overloading the charger. The laptop will not turn on unless it "thinks" the battery is charged enough to operate the computer. Even though you have the AC power connected and your adapter may be OK, it is still possible that:
Larry
SOURCE: no singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
