The lights on the a/c controls and the stero controls quit working. Also the cd player picks and choses when it wants to play
Check charging system..may have a bad alternator. good
luck
The charging system is run by the alternator it just a basic check of the system. may I suggest an Auto-zone they do it for free they have a portable machine it checks that battery the alternator and even a starter draw. They just bring it out to you car in the parking lot and check for you. I really think its the alternator but I wanted to make sure by checking the entire system, try them it take just a second.
http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on
Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003
Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise
Control stops working, Excessive cranks to start the engine and RPM goes max
2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring
Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Would the alternator not cause other problems as well? What is the charging system and how do I check it?
I have this same problem on my g35 03. The alternator has been tested and it's normal. Any other suggestions?
Cheers!
I took my car in for soemthing similar.
The lights go out in the center panel, G35 sedan 2003 (first model year). Then the buttons no longer work and the air conditioner comes on and can't be stopped since the buttons don't work as the lights are off.
What i was told is that the radio and air unit, are on the same circuit and it's caused by a glitch in some of the radio units.
The mechanic himself came to speak to me. he said they've seen in in 3 cars in 4 years so it's not a huge issue but sounds like you and me got some rare bad radio batch or something.
They ordered radio for me (warranty over so had to pay $400 cdn for it)....and will replace it. It better work ...
Sanjay
my drivers side door wont lock most of the time it clicks but doesnt catch, my speaker on my drivers side goes in and out and the same goes with the light on the left side :(
thoughts?
Wow, I have the same problem with my 03 G35 where the radio lights go out and the air comes on( and wastes my gas) and none of the buttons work, and what did the dealer say causes this?
I have the same problem as starfyrexxx. All the lights went out and then radio and ac dont work. The AC is on but I can turn it off or adjust anything.
same here, the center panel just went dark & the AC just run by itself. 2003 sedan. wonder how many people have the same issue.
I had a "draw" on my battery and was told by the dealer that I needed to replace to radio in order to completely fix that. instead I had them unhook the radio, which is connected to the climate control, leaving me with 72 degrees constantly in my car and no radio or fog control.
I also have a 2003 G35 Sedan which has the same problem. The radio and AC control buttons dont work and the lights go out as well. The car has 95,000 miles on it.
I have a G35 infiniti and it is making a kind of rattling sound when excelerating, it almost sounds like a diesel,
