I having problem to connect my modem it lock the wifi feature . im using bsnl broadband
SOURCE: adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
SOURCE: non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
SOURCE: I have BSNL broadband with Siemens SL_2 141 modem
First get IP of Siemens SL_2 141, start- run -cmd- ipconfig /all
Note down Default Gateway IP address ( Generally 192.168.1.1)
Type it in Internet Explorer address bar and hit enter
put username admin, pass admin
Click Wirelles then in Basic setup, Enable Wireless, Enter SSID as BSNL, transmission mode 802.11g, then remaining option as auto, do not keep security now let it be disabled, click apply or save and rebot the router.
Install Netgear software in ur desktop let search for ssid BSNL and connect automatically. Once connection gets establish then set security WEP-PSK and put password also in Netgear u have to mention same password whil connecting.
More help here page no 97
any query revert,
Thanks
