Kenmore Elite 45986 Front Load Washer Logo
Anonymous Posted on Dec 19, 2008
Will not drain
My frontloader will not drain. it has standing water in it. when i put it on the drain cycle it gives me a little bit of water thenclicks to the drain cycle and nothing happens. it makes a humming sound. the hose is not cloged. i removed the front cover and opened the white drain plug in front and cleaned that out. still does not work. the tub does spin throgh all this.
  • Anonymous Dec 19, 2008
    how do i test the drain pump? is ther a way to test the timer?
Ginko
Level 3:
  • Kenmore Master 19,396 Answers
  • Posted on Dec 19, 2008
Ginko
Kenmore Master
Level 3:
Answers
19396
Questions
25
Helped
8073370
Points
55462
If the drain lines are clear, test the drain pump, and see that drain pump is not clogged by removing it and cleaning.
If the drain pump is fine, then it is probably a defective control timer.
You can find machine diagrams and replacement parts by entering model number here.
1helpful
Hi,my machine skips putting in water and goes to drain cycle immediately. So no water goes into the machine
does the water get to a certain level but keeps filling while draining down your stand pipe. if so the end of your drain hose os pushed to far down the stand pipe and is syphoning out. a bit common. pull the end o the hose up closer to the opening.
1helpful
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
1helpful
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
2helpful
2answers
Won't drain right
Check the pump. There is most likely something obstructing it. It is probably a coin or something like that. There should be 2 hoses that attach to pump. One that the water comes into and one that the waterwill discharge. It will be one the the water discharges from. Make sure that you get a pan or bowl so when you disconnect the hose the water will go in this instead of on the floor.
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
Water to dishwasher not hot enough
The 737 model could run on even lower temperature (80F). Given time, the unit will heat up the water. the trick is to give it time.
That model is made for commercial use, not really for residential. It will not fully drain every cycles. The important thing to keep in mind is to empty the dishwasher (turn it off, pull the stand-pipe out, and drain) every night and left empty. When you want to use the unit, put the plug back in and turn it on, wait 20 to 30 minutes and it should be ready.
Robert Marsolais
2helpful
3answers
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Alexander
vince
