SOURCE: how to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
SOURCE: panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
SOURCE: How to set time on Panasonic KX-T7633
From the system administrator's phone, enter programming and dial 000 and follow the prompts using the FWD and CONF button to move the cursor back and forth.
Carl
SOURCE: How do I forward calls to an outside number
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Testimonial: "Replies have been very useful and informative."
