Cant turn on the laptop because there is a black screen and message with that file that is missin or corrupted
You probably have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
SOURCE: toshiba laptop problem
Ah , that simple means you have some corrupt files.....we can try a couple of things before getting too dirty:
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
This should get you back on your feet, if not let us know and I can give you some further assistance!
SOURCE: windows could not start because the following file
If you did have the CD, instructions as per Microsoft can be found here:
http://support.microsoft.com/kb/315338
Without the CD, you could always try to transfer the file from another working system. Can you start the computer in Safe Mode?
If not the easiest way to transfer the file, might be to take the hard drive out of the affected system, and temporarly install it in place of the CDROM on a working machine. Boot, then transfer the missing files.
I dont have the CD, and when I type md tmp, it says access denied... What else can i DO? THANKS A LOT!!!
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up. Kaspersky rescue cd download:http://majorgeeks.com/downloadget.php?id... Imgburn download:http://majorgeeks.com/downloadget.php?id...
