Continental CE-PAC1163 Air Conditioner
SOURCE: i have continental electric model ce-pac1061-1 where can i find
Try your local machanic or even junk yard. Thsi will help.
SOURCE: I have a Continental portable air conditioner
YOU CAN MAKE ONE WITH DRYER VENT PLEX GLASS IF YOU CAN NOT FIND ONE
SOURCE: I have a Continental Portable airconditioning unit that I have to drain every couple of hours?
your problem is that u need a general cleaning ,an with out that u will still have that problem.Now if you have a little knowledge on how to open the system thats somthing u could do yourself..Once u get the system open locate the drain assembly ,make sure that pan an hose both are cleaned out an while you are there go ahead an clean the coils on the unit to prevent any head pressure an that the unit supplies air properly if you dont have any drain cleaner for your unit use ,bleach just a little cap full an pour in pan..an after you get it clean.once a year pour in drain hose ..That should take care of your problem
SOURCE: I'm looking for some troubleshooting
HI> You may try this website.http://www.hammerwall.com/Manuals/Continental%20Electric/305/Lookup/Air-Conditioner/77/ Hope this helps..
