Cut out dimensions for installation
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
SOURCE: F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months). Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
