If the problem is same with different input devices and you have ensured
the are no loose contacts in power outlet, RC jack, cable and sockets,
the TV needs servicing.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Convergence amp ic bad http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html http://www.hdtvoice.com/voice/showthread.php?t=28929 Or send to ptscorp.com
