The code you are looking for is 1340. I have the same TV and my sky volume hasnt worked since I bought it, (9 months ago).. After spending an age on the SKY forum with no luck, I simply googled (Sky remote codes) and clicked on the 1st site, it's skyremotecodes.co.uk then Samsung 6000 series.... It told me the correct code and gave me clear instructions...... I hope this helps someone else.
Hello, Can you giv me orginale setap picture for Samsung ps43e45*/49*
SOURCE: Samsung Remote Issues
if the tv is a new tv along with remote take it back to the supplier it should still be on warrant.good luck
SOURCE: Samsung (RS105N) Remote Control
Found the user manual here
http://www.directv.com/learn/pdf/System_Manuals/Samsung/Samsung_SIR300-310W.PDF
SOURCE: need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
SOURCE: remote tv control
http://www.scribd.com/doc/2304654/Samsung-HPS4253-Manual
page 43 and 47
cheers
Richard
SOURCE: I need a code for my Samsung tv model
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
Try the codes above and report back.
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
