Car keeps over heating not sure weather thermostat is no good or waterpump no good
Try thermostat as water punp would be leaking or sqealing if it was the water pump check all cheap things first 99% thermostat is stuck
Yes all EJ subaru engines drive the water pump trough the cam belt, and the cam belt have to come off to replace the water pump, for good trained mechanic its about 2.5 to 3 hours work to do the cam belt and water pump.
First things first, is it actually loosing any coolant?
If not, is the guage actually telling the truth?
If its throwing coolant from the overflow reservoir with the cap on it could be (a) a head gasket is leaking, (b) the pressure cap is faulty.
If not and its just running hot look at things like the thermostat, but don't run without one. The coolant circulates too fast thro' the rad to be properly cooled. If you want to try this get a pair of side cutters and cut the middle moving part out of the thermo' and replace the ring in the housing. This will simulate the thermo' being wide open whilst restricting the flow to the designed level.
Is the rad hot all over when the guage says so? It should be well hot all along the upper half and cooler lower down?
Modern rads are mostly aluminium with plastic end cases and if the coolant is not flushed and replaced at the correct proportions even in warm climates the rad will fur up inside like a kettle. They cannot be effectively cleaned and most have a life of 6-8 years or 75-80k miles.
The key to all this is correct diagnoses of the problem before a penny is spent.
Help from someone will good skills will prevent an accidental discharge of the wallet!!
