So everytime i turn it on to listen to some music, i tap the touch arrow to scroll down & it wont go anywhere...i've had it for a few months & it's worked fine, but the past few days its stuck & wont scroll anywhere, how do i fix it?!
I tried the reset button but it still does not work
See if you have a warentiy. Than you might be able to get a new one.
This happened to me before. What I did was that I found the little reset button and pressed it and I then turned the player back on and It worked normally again. Hope this helps P.S: The scroll buttons may be broken.
1Press the "Src/Off" button until the Pioneer CD player turns off.
Press and hold the "Src/Off" button again until the clock displays in the unit screen. In some Pioneer units, hold the "Multi-Control" button until "Clock Set" appears in the display.
Press the "F" (Function) button on the front of the CD player. In some units, press the "Multi-Control" button again to enter the setting mode.
Touch the left or right arrow buttons, or "Multi-Control," to select the segment of the time you want to change (e.g., hour or minute).
Tap the "Up" and "Down" arrow keys, or turn the "Multi-Control" button, to scroll through and select a number for that field. For example, if changing the hour to "2," scroll up or down until you get to the two. Use the right arrow to scroll over to the minute segment of the display. Use the "Up" and "Down" arrow keys to select the numbers that make up the appropriate number.
