Just a simple answer, when the charger is plugged into the chair do you turn on lights? leave off? then how do i know when it's fully charged.
SOURCE: jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
Yes, the main controller module can be very expensive to replace. I would take it to a reputable dealer if the battery replacement does not help.
SOURCE: My hoveround MPV5 will not operate. fully charged
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
SOURCE: Jazzy 1121 power chair won't go
It may not be the joystick. I have had the same problem before. The edel cable that goes from the joystick to the back of the wheelchair could be bad. You can try unplugging it and plugging it back into the joystick. Check the prongs on the cable and make sure their not broke. You can also try flipping the switch that is located down by the charger under the chair. The cable is around $200 and the joystick is quite a bit.
thanks all i need to know
