Nokia N-Gage QD Console Logo
Posted on Mar 28, 2017
They dont have a records of my ime #
Please help me,, i need the activision as much as possible,,, vampent didn't recognized my ime #.......... please help me to fix may vbag application on may n-gage qd console!!!
Please Help me, i downloaded the vbag application and some gba games on myn-gage qd console but the vbag application did no recognise them. I think i have to activate it please send me my activation code i need it very urgently if not even today please send it to my email [email protected]
My IMEI Number Is 353360001264929
thank you,,,,,,,,pls, give me only the code,,, i hope you will give the best response on my problem....thank you!!!!!!
2 Related Answers
Anonymous
  • 84 Answers
  • Posted on Dec 18, 2008
SOURCE: actision code of my vbag my serial number is 353360001264929
use this website
http://www.vampent.com/activate.php
works for the paid serial codes
please rate"
jmthanz
jonathan mariano
  • 344 Answers
  • Posted on Dec 23, 2008
SOURCE: activision code
353360001264929
code: 681009035699576123456789012345
Low speed card,please record at a lower resolution
Not all memory cards are created equal. Some cards are faster than others. There's more data to be recorded with a high-definition video than with a lower-resolution video. Your card apparently isn't fast enough to handle that much data.
There are two possible solutions. One, as the camcorder suggests, is to record at a lower resolution. The other is to get and use a faster card.
Since you didn't specify the make and model of your camcorder, I can't tell you what speed card you need. Please refer to the specifications page in the manual, or the section on memory cards.
How can i get mai vbag activation code pls help me!!!!!!!!!!!!!!!!!!!!!pls
You can have it from the following link:
http://www.vampent.com/vbag.htm
For extended use, you may have to purchase it.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
I have about 10 interviews on my recorder. It recorded fine, but when I plugged it into my computer it says I need to format it. Is there anyway to get this information off of here, even if I have to...
DO NOT format the recorder. That will wipe it clean. The computer does not recognize the device. There must be a piece of software needed to allow the computer to recognize it. If you have an old pc forget it. Dont know about macs.
I've downloaded the map packs for world at war, but when i go to select them from my start menu its like the map packs dont exist....im confused, never had a problem like this. any deas???
I had the same problem. I had to delete the maps and reinstall them once I was in the game. After that it should recognize them. Once in awhile it will still do it but I just restart once (or twice in some cases)and it recognizes them.
Let me know how it goes or if you need anymore help
1helpful
10answers
I need the 16 digit code to unlock the phone
could you unlock mine i can give you my IMEI aysaam
4helpful
4answers
N81 vBag serial
665516876843583123456789012345your code
Apr 03, 2008 • Nokia 6600
9helpful
10answers
Net unlock code LOBSTER 320
i also have same problem, My name is Eddie, Email Address is [email protected] IME : 354127010311655 AND IME 354127016694617
2answers
Unlock code
I NEED MY PUK CODE TO UNLOCK MY PHONE IT WONT UNLOCK IN DONT NOE WAT THE CODE IS
4answers
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Top Nokia Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Nokia Video Game Console and Game Expert? Answer questions, earn points and help others
